Support DJI Mavic mini with Pix4Dcapture
Buongiorno a tutti,
pure io sono interessato a poter avere il Mavic Mini su Pix4DCapture. Io provengo dalla Svizzera Italiano. Speriamo che presto sia possibile.
Bene, allora insistiamo e teniamoci in contatto ing.anelli@tin.it P.S.: titolare di licenza o solo interessato a Pix4D?
Invito quanti fossero interessati a formare un gruppo per scambio di pareri, collaborazioni possibili e…quattro chiacchiere su Pix4D rigorosamente in ITALIANO :wink: Scrivere per adesione a: ing. anelli@tin.it
Hi, it was mentioned that pix4d capture will be able to control mavic mini by April 2020. Any update on that?
It seems very hard due to Covid-19 pandemic emergency, I think
Speriamo al più presto a fine aprile al rilascio di questo benedetto SDK, almeno da poter lavorare anche con il mavic mini :smile:
Understood, is it possible to know the gsd value for mavic mini at 50m
how do you process the imagery in pix4d desktop? i have tried and get a error on camera calibration.
Is amici mini inserted in Pix4Dmapper Pro database or did you create a ā€œspecific cameraā€? In the second case, what parameters did you insert for Mavic Mini camera? P.S.: we are still waiting for Mavic Mini in Pix4DCapture, sigh!
Hi, any updates on pix4d and mavic mini?
Are you still waiting? I’m not: ask for a quote. P.S.: I think that Mavic Mini is only a commercial invention not a professional drone IMHO.
well topodrone have converted it to a ppk/RTK solution so it has commercial applications. its perfect for certain applications
It is not so cheap…and the wind can blow it away IMHO
Hello everyone,
There are no plans to support the DJI Mavic Mini in 2020. If things change, we will post here to inform the community.
Thank you.
What a wonderful news!
wonderful???
@guiduz Do you know what irony is?
An huge number of Pix4D Capture and Pix4Dmapper Pro owners are asking this.
Sorry, you can’t close every post I publish.
This is not the way in my honest opinion: you can’t close everything is wrong for you but interesting for others.
