Hi Antonio,
Your post was merged with the older post so that we have all the information in one place. This is why we close all duplicated community posts related to the same topic. You can find your old post here.
I am also going to move this post to the same community post. I would suggest you not to create any duplicate post anymore. As I have already mentioned that there are no plans to support the DJI Mavic Mini in 2020. If things change, we will post here to inform the community.
Estimados, necesito saber si existe compatibilidad de PIX4DCAPTURE con el drone âMavic Air 2â. En la aplicaciĂłn y web indica que es compatible con el modelo âMavic Airâ, pero no aparece la Mavic Air 2. HabrĂĄ algĂșn inconveniente si selecciono Mavic Air para utilizar mi drone âMavic Air 2â?. Se puede o hay que esperar a una nueva actualizaciĂłn de PIX4Dcapture? Quedo atento, saludos.
I just purchased a Mavic Mini and another farmer mentioned your software. Too bad I canât use it with my drone - or perhaps you will support it and gain another customer!? Would hate to have to buy another $1500 drone after spending $500 on the Mini to use this software.
The DJI has just released the SDK for Mavic mini drone. That means the third party software should now be able to use it to do automated flight planning. At the moment, it is currently not in our pipeline to support the drone in 2020. Just to let you know, if the Pix4Dcapture app does not support your drone at this time, you can use any other image acquisition software and still process the data using Pix4Dmapper. Pix4Dâs software is drone/app agnostic, meaning that you will be able to process image data obtained from different image acquisition app or the drone.
I doubt if there is any image acquisition app other then the one from DJI with limited features. They have recently released the SDK, so it will take some time for the other third party software to support the drone. I would also suggest you to wait for the reply from other users to see what workflow they have been using for image acquisition.
I recommend Dronelink, it works with the Mavic Mini. Missions can be planned on a computer and unlike Pix4D, they quickly update the application with new drones. The program offers many more options for planning photogrammetric missions than Pix4Dcapture.
That is $20 to buy. I am not sure how easy it is to use being web based and how you connect to Mavic and all that.
I tried to program with Android SDK but unfortunately Waypoint mission still is not supported for MAvic mini and only mobile remote works. This should be still doable but takes more work. If anyone is happy to assist with formulas I can do Android program. amirfarazmand@gmail.com
Hi Javier! Sorry I didnât see this when you first posted it. The mapping results look great. I too have flown my Mavic Mini the same way, using a manual flight path with timed auto shutter. Itâs fine, but I really do want to use Pix4D Captureâs automated flight path eventually. Having a preset overlap and sidelap would ensure consistent results. Thanks for sharing your project.
Hello, how are you? If I really am waiting for pix4dcapture to finally put the mavic mini, for me it is the planning program I will trust in real-time planning situations. Greetings to all from the Dominican Republic
We are looking for the good data set from the DJI Mavic mini with 4000*3000 resolution. We are going to calibrate the camera model and include it in our Pix4Dmapper and Pix4Dreact camera database. A good dataset with the following properties is required:
Enough images (100 - 150 images).
Non planar scene (not all objects having the same height)
High overlap and rich texture.
Several grid flights (at different heights) OR oblique imagery with sufficient overlap.
If possible, with GCPs. https://support.pix4d.com/hc/en-us/articles/206065716-How-to-calibrate-a-Perspective-Lens-Camera.
If anyone can provide a good dataset, please let me know.
DJI has just released an SDK for the Mavic mini drone. This means that your companyâs software is able to use it for automatic flight planning. At the moment, no one plans to send you drone photos in 2020. We just want to inform you that if the Pix4Dcapture app does not currently support the Mavic Mini then you can use any other image acquisition software and still process the data using Pix4Dmapper. The Pix4D software is drone / app independent which means you will be able to process image data obtained from another image capture app or from the drone.
Greetings,
