I downloaded and loaded the app today.
Very disappointed that it does not have the ability to do Free Flight as the non-pro version did.
Fist issue was the new custom RTK not connecting. I finally had to reopen Pilot2 and re-connect to custom RTK (it was previously connected) and then close Pilot. It did work after that.
I planned a simple Grid flight and it came up all green and said it was taking off but it would not. It then said mission complete and the app crashed. This happened several times and with different missions And yes, the Pilot 2 app was force closed at the time.
The only way I could get it to work was to start in Pilot 2, get the drone airborne, then force close Pilot and start Capture. Then it completed the mission, though at the end, it did not return home, but instead switched to manual flight. This is even though I have RTH selected for end of mission.
So it’s workable, but not efficient at all.
I’m experiencing the exact same issue.
Hi
Welcome to Pix4D Community!
Thanks for reporting this problem. I just informed the developers, they will start investigating this issue shortly.
Thanks in advance for your patience.
We will be reporting as soon as possible about the fix.
Have a very nice day!
Best regards
Just wanted to add to this and also say that I experienced the same issue today (05/16/23). Similar to Austen, the only way I could get the app to execute the mission was to take off in DJI Pilot 2, close the app then open Pix4D Capture Pro and start the mission there. If I were to do it in any other order, the app would crash. I also was not able to get RTK to work properly within the app either. It would connect but then as soon as I try to run a mission the whole app would crash and not all me to do anything until I restarted the drone and controller.
Hi @Austen_Proctor
Please could you send us the log files? This will help us to investigate the issue.
I am looking forward to your answer.
Best regards
Hi @dylan1
Best regards
I just wanted to add a few more details.
I have tried every mission type and have been unable to take off while using capture pro. Most of the time the app crashes after you try to start the mission, sometimes it doesn’t and just marks the mission as complete.
Having RTK connected or disconnected does not affect the issue.
Dylan & Survey11,
Here is what they sent me after I uploaded my log files:
Hi Austen,
Thank you very much for your detail replied and for sharing the log file.
I shared all the information and the log file with the developing team.
Our developing team is aware of this issue. We identified it as a bug. We are working on identifying the cause. However, the time needed to fix this bug is not completely in our control at the moment. This bug may take some time as we also are in contact with DJI to see what could be the cause. Nevertheless, we understand the priority level of this issue.
Once we fix it, we will announce it immediately in the following articles:
Technical release notes (Android) - PIX4Dcapture Pro
Technical release notes (iOS) - PIX4Dcapture Pro
Once again, we appreciate your patience with us. Thank you for reporting this.
Hi @survey11
Thanks for sharing the details.
For now, what we need to have are several log files where we can study this issue in depth. If you could send us this information, we would appreciate it.
Thanks in advance for your collaboration.
Best regards
