Hello;
I have a mac with the M1 chip, I think Mac directly is not compatible with Pix4D. But if I install windows with Parallels it will work with the M1? Thanks
Hello;
It is recommended to use Windows 10, 64 bits; however, it is possible to use Mac computers using Boot Camp. For more information about system requirements, please go to the link below.
System requirements: Minimum and recommended computer specifications
Please note that there is a Beta macOS version of Pix4Dmapper 3.0. You can install it by following the steps below.
How to install the macOS version
It is not intended for production or professional usage; however, if you can use only Mac, it is an option. For more information; Beta macOS version of Pix4Dmapper 3.0.
Kind regards,
Hi, I have installed Parallels on the MacBook Pro M1 Max.
It is 3 times slower than my 2017 MacBook.
I made a post with report in another thread.
Attempting to rectify issues.
I guess running slow is somehow expected. The M1 has to translate the OS from intel instructions to ARM. It is really not meant to run windows in any way.
A lot of people are using the OSX version of PIX4Dmapper that works well for them on the M1 but it is expected to run slow though as you mentioned.
I hope you found this helpful.
