It is very important that you do not generate output files that you are not interested in. For example, if you are not interested in the 3D textured mesh, it is better to deactivate the option that generates this file.
One of the options that makes the processing faster is the “Targeter Number of Keypoints”. You can adjust this options to the 20000 value (it is recommended for RGB images and not multispectral images).
For a large projects (over 500 images at 14 MP), we usually recommend 32 GB RAM, 60 GB SSD Free Space.
To better understand the use of resources during processing I recommend you this article:
[Hardware components usage when processing with Pix4D
](/hc/en-us/related/click?data=BAh7CjobZGVzdGluYXRpb25fYXJ0aWNsZV9pZGkEH9ASDDoYcmVmZXJyZXJfYXJ0aWNsZV9pZGkEaccSDDoLbG9jYWxlSSIKZW4tdXMGOgZFVDoIdXJsSSJWL2hjL2VuLXVzL2FydGljbGVzLzIwMjU1OTUxOS1IYXJkd2FyZS1jb21wb25lbnRzLXVzYWdlLXdoZW4tcHJvY2Vzc2luZy13aXRoLVBpeDREBjsIVDoJcmFua2kG–bac2a839a3f8437bd00dbf8e328562f22d0d0909)It is also usually recommended to process your projects on the SSD and to store the images on the SSD while processing.
It is not necessary to have Pix4Dmapper installed on the SSD, but it would allow the software to launch faster. However, you should process the project on the SSD with the images on the SSD as well for the maximal performance. The different steps use the resources of the computer in a different way and in some steps (especially during step 3) the hard drive is used a lot to read and write the results.
Typically the projects have 400-700 images (± 8 MB) and resolution 3-6 cm.
In fact I only need the orthomosaic and DSM so I can deactivate a lot of options?
Since I am at the moment waiting for a license (purchased by the university), I only use the trial version for now and cannot adjust the number of targeted keypoints I think.
The computer we bought has 16 GB RAM. Where can I setup that the process needs to be done on the SSD?
Medium projects (between 100 and 500 images at 14 MP): 8 GB RAM, 20 GB HDD Free Space.
Large projects (between 500 and 2000 images at 14 MP): 16 GB RAM, 40 GB HDD Free Space.
As you only need Orthomosaic and DSM, you can uncheck the box “Generate 3D Textured Mesh”.
With a trial license you have full access to Pix4Dmapper and therefore to all processing options.
However, if you do not face crashing, I recommend you to keep the Number of Targeted Keypoints on Automatic.
You do not need to set up any thing. You should just have your images and your project saved on the SSD.
Hello everybody
I have a Dell PowerEdge R730 two processors Xeon E5-2620 v4 64
GB RAM 10 TB SAS and Nvidia Quadro RTX 8000 GPU What is the best Hardwares for me to make a project of 3000 images at a height of 500 meters and a resolution of 24 megapixels and to finish the process in two days?
