Pix4d mapper with UHD 4k monitor crashes on Step 1 of processing
Hi all,
I have a i7-6700 PC with a Geforce GT 710 of 2gb 16 GB RAM and windows 10.
The software crashes on step 1 of processing without flaggin anything. The computer is powerful and should be able to process this pictures.  I am using a 4k UHD Samsung monitor with a 3840x2160 (60 Hz) resolution and I think it may be the problem although I cannot figure out what to look for as a solution. I have done this processing with an ASUS laptop and the software behaves correctly.
Does anyone have any recommendations?
Thanks in advance
Hey Victor,
I will need more details to assist you.
  • Did you process the exact same project with the ASUS laptop?
Can you please send me both log files?  You will find the log here: …\project_name\project_name.log
Additionally, please send me the machine specs:
  1. Click the Windows Start icon and type System Information. Select the application in the list above.
  2. In the application, click File > Save… and export the content.
  3. Attach the file your_file.nfo to the reply.
