Hey everyone,
I have been using Pix4DMapper for a while now but I am facing issues during processing & I could really use some help. I am working on a project with a large dataset, and for some reason, the processing gets stuck at different stages—sometimes at step 1 and other times during the DSM and Orthomosaic generation. My system has decent specs high RAM and GPU so I do not think it is a hardware issue.
I’ve tried adjusting processing options, lowering image resolution, and even running the project on a different machine, but the issue persists. Has anyone else experienced this? Are there specific settings I should tweak to improve stability? Also, does Pix4DMapper have a preferred file format or naming convention that might be affecting things?
While troubleshooting, I was also looking into a Java course online to automate some tasks—has anyone tried integrating coding solutions with Pix4D?
Also i have see this Why is Pix4D Mapper very poor at processing times with multi processor support? . I appreciate any tips or advice.
Thank you…![]()
