Hello!
After the Initial process, I can see an area of the PointCloud which does not consist of any TiePoints.
After step2 and step3 calculation, I saw that the blank area is only in the calculated .las file in the PointCloud. I need the PointCloud to create surface for Volume Calculation and some drawings.
I tried with MTPs - still no result after running again the Initial process.
I tried with/w-o Geometrically Verified Matching - still the Same result.
In the Quality report everything is looking normal, as usual. The Orthomosaic and DSM are fine, as in DSM I can see clearly that the missing area in the Ray Cloud is taken into account and calculated.
I hope I won’t need to Fly it again, since the Date was important in this case.
DEPO10km-09022021_report.pdf (1.5 MB)
