Hi guys,
After merging project together and solved some accuracy errors with MTP, I get empty area on my building roof.
Can someone explaining that ?
Thank you!
Hi guys,
Thank you!
Hello Benjamin,
The recommended procedure to merge two projects is:
Best Regards,
Hello!
Thank you for your response and explanations.
To merge sub-projects (1 aerial, 1 terrestrial), I created identical MTP on both, and created a new project to merge them.
Roof points was visible only on aerial project (obviously…)
But on the terrestrial project I annotated the sky (carve option), and due to a bad accuracy, I think it erase some points from the Aerial project…
So I think this issue is due to my annotations…
Maybe It’s better to merge projects together in a first time and then use the annotation option…
