I’m using a DJI Matrix 210 drone coupled with Zenmuse X5S, Rededge M, Zenmuse XT2 (13mm, 640x512 – image 1) and Pix4Dmapper to process the images.
I have some problems when I process thermal images. In the New Project wizard / Processing Options / Template window, I select Thermal camera template but I can’t check the thermal_ir index to be generated because in the Indices box I find grayscale = grayscale and not thermal_ir = thermal_ir. Is it the same, do I get the same result?
I cannot then complete step 3. Below is a summary of the log file.
[2019.08.17 08:10:28][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “ImageDescription” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:28][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “Model” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:28][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Error <1> MissingRequired:TIFF directory is missing required “ImageLength” field
[2019.08.17 08:10:29][31%RAM][10%CPU][Info]: Loading cameras [Grayscale] [84/98] elapsed 07s:011ms …
[2019.08.17 08:10:29][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “ImageDescription” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:29][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “Model” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:29][31%RAM][11%CPU][Warning]: Warning w9020: GDAL Error <1> MissingRequired:TIFF directory is missing required “ImageLength” field
[2019.08.17 08:10:29][31%RAM][10%CPU][Info]: Loading cameras [Grayscale] [90/98] elapsed 07s:511ms …
[2019.08.17 08:10:30][31%RAM][10%CPU][Info]: Loading cameras [Grayscale] [96/98] elapsed 08s:012ms …
[2019.08.17 08:10:30][31%RAM][9%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “ImageDescription” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:30][31%RAM][9%CPU][Warning]: Warning w9020: GDAL Warning <1> TIFFFetchNormalTag:ASCII value for tag “Model” contains null byte in value; value incorrectly truncated during reading due to implementation limitations
[2019.08.17 08:10:30][31%RAM][9%CPU][Warning]: Warning w9020: GDAL Error <1> MissingRequired:TIFF directory is missing required “ImageLength” field
[2019.08.17 08:10:30][31%RAM][10%CPU][Info]: >>>Loading cameras [Grayscale]<<< done in 08s:513ms / 0.141883 min.
[2019.08.17 08:10:30][31%RAM][10%CPU][Info]: Ortho gain: loading from disk.
[2019.08.17 08:10:30][31%RAM][10%CPU][Processing]: Analyzing DSM
[2019.08.17 08:10:31][31%RAM][10%CPU][Info]: >>>Analyzing DSM<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:31][31%RAM][10%CPU][Processing]: Loading DSM
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: Loading using the color mapping:
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: palette = Atlas, mapping = gradient, shading = enabled, order = min-to-max, clamp = enabled, alpha = nodata
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: X {band = 0, range = [186.664, 194.132]}
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: R {band = 0, range = [0, 255]}
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: G {band = 1, range = [0, 255]}
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: B {band = 2, range = [0, 255]}
[2019.08.17 08:10:31][31%RAM][0%CPU][Info]: A {band = 3, range = [0, 255]}
[2019.08.17 08:10:31][31%RAM][10%CPU][Info]: >>>Loading DSM<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:31][31%RAM][10%CPU][Info]: Loading DSM [0/1] elapsed 000ms …
[2019.08.17 08:10:32][31%RAM][5%CPU][Info]: >>>Loading DSM<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:32][31%RAM][5%CPU][Processing]: Analyzing DTM
[2019.08.17 08:10:32][31%RAM][5%CPU][Info]: >>>Analyzing DTM<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:32][31%RAM][5%CPU][Processing]: Loading DTM
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: Loading using the color mapping:
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: palette = Atlas, mapping = gradient, shading = disabled, order = min-to-max, clamp = enabled, alpha = nodata
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: X {band = 0, range = [186.68, 193.376]}
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: R {band = 0, range = [0, 255]}
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: G {band = 1, range = [0, 255]}
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: B {band = 2, range = [0, 255]}
[2019.08.17 08:10:32][31%RAM][0%CPU][Info]: A {band = 3, range = [0, 255]}
[2019.08.17 08:10:33][31%RAM][5%CPU][Info]: >>>Loading DTM<<< done in 500ms / 0.00833333 min.
[2019.08.17 08:10:33][31%RAM][5%CPU][Processing]: Loading DTM
[2019.08.17 08:10:33][31%RAM][5%CPU][Info]: Loading DTM [0/1] elapsed 000ms …
[2019.08.17 08:10:33][31%RAM][5%CPU][Info]: >>>Loading DTM<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:33][31%RAM][5%CPU][Processing]: Analyzing orthomosaic [Grayscale]
[2019.08.17 08:10:34][31%RAM][7%CPU][Info]: >>>Analyzing orthomosaic [Grayscale]<<< done in 500ms / 0.00833333 min.
[2019.08.17 08:10:34][31%RAM][7%CPU][Processing]: Loading orthomosaic [Grayscale]
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: Loading using the color mapping:
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: palette = Grays, mapping = gradient, shading = disabled, order = min-to-max, clamp = enabled, alpha = alpha
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: X {band = 0, range = [13.2516, 33.2477]}
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: R {band = 0, range = [13.2516, 50.3202]}
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: G {band = 0, range = [13.2516, 50.3202]}
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: B {band = 0, range = [13.2516, 50.3202]}
[2019.08.17 08:10:34][31%RAM][0%CPU][Info]: A {band = 1, range = [0, 255]}
[2019.08.17 08:10:34][31%RAM][7%CPU][Info]: >>>Loading orthomosaic [Grayscale]<<< done in 501ms / 0.00835 min.
[2019.08.17 08:10:34][31%RAM][7%CPU][Info]: Loading orthomosaic [Grayscale] [0/1] elapsed 000ms …
[2019.08.17 08:10:35][31%RAM][7%CPU][Info]: >>>Loading orthomosaic [Grayscale]<<< done in 500ms / 0.00833333 min.
[2019.08.17 08:10:35][31%RAM][7%CPU][Processing]: Step3Done
[2019.08.17 08:11:28][31%RAM][4%CPU][UI]: Save Project clicked.
[2019.08.17 08:11:31][31%RAM][7%CPU][UI]: Closing Project.
[2019.08.17 08:11:31][31%RAM][7%CPU][Info]: index calculator: saving image pool: indices/grayscale/16ago19_thermal_grayscale.pool
[2019.08.17 08:11:31][31%RAM][7%CPU][Info]: index calculator: saving settings
[2019.08.17 08:11:31][31%RAM][7%CPU][Info]: DataProvider: closing
Thank you,
Michele
