I have a new Zenmuse XT2 camera and would like to create a thermal mosaic. Although I have not flown a grid yet (as I have an M210 and DJI Pilot can’t do that yet) I thought I would try with some images I collected using a 5 sec interval. To test PIX4D I tried loading a few of these images but I immediately received the following error after uploading the images. Any thoughts on why this failed so quickly?
[Error]: Error converting FLIR image: This is not an IR image: C:/Users/Desktop/100MEDIA/DJI_0011_R.JPG
We currently have difficulties in extracting the r-jpeg imagery from FLIR cameras. We have contracted FLIR from our side to see what causes this issue. We believe that the latest changes of FLIR SDK do not align with our algorithms.
As soon I will have news from my side I will write you back.
A workaround is to use the flir tool (ThermalFolder.exe) and change any setting (I use emmisivity). After that the modified versions can be extracted by Pix4D.
Did you fix the issue? I am importing images collected from the XT2 and Pix4D is converting them to greyscale. When i want to open them in the map view, there is no visible content.
If i try to run Step 1 the error “Exception found trying to select keypoints: Input keypoints are empty” shows up.
This error seems to indicate that the software could not detect key points while processing and thus couldn’t find the results that were generated for step 1. Initial Processing.
Do the raw images look good?
Have you checked the camera settings before capturing?
The images are looking okay for me. But it was the first time i have done that so i have no comparison.
It seems as if Pix4D is not able import these images properly as i am not seeing any content when opening them in the Map View. They are automatically converted to greyscale, but this only works for some images. Most of them are like 45kb with no content at all.
