Hi @jlmitchell42,
Yes, Windows 11 is still not a supported OS for PIX4Dmapper.
However, this does not mean that it does not work at all.
Many users reported good experience using Windows 11, while others have issues when OneDrive syncing the Desktop folder. In this case, disable the sync of that folder. You can find more information here:
Also, because it is not supported, you may encounter some malfunctions that are not known/documented yet. Therefore I wouldn’t suggest using Windows 11 for production work unless you have a backup computer with Windows 10 that you can use in case of malfunction in the Win11 device. This will allow you to deliver your results on time.
I’m sorry I couldn’t give a better answer; I hope this is still helpful.
Let me know what you think and if you are getting good results.
Happy mapping
