What is required and how to do stand counts
PIX4D software does currently not offer automatic standcounts. But you can use the map outputs like the high-resolution orthomosaic as an input for 3rd party counting solutions.
For fast orthomosaic processing you can look at PIX4Dfields. In its upcomming 2.7 we will introduce a manual counting feature, which you could use to assess the stand of your crops by sampling a few regions of your field.
HEY THERE,
Stand counts are a way to measure how many plants are growing in a certain area. Here’s what you need and how to do it:
What You Need:
- Measuring Tape: To measure the length of rows or areas.
- Markers: To mark the start and end of the measurement area.
- Notebook or Phone: To write down the counts.
- Calculator: To figure out the plant density if needed.
- Optional: A GPS device for precise locations.
How to Do It:
Pick Random Spots: Choose several random areas in the field to get a good average count.
Measure the Area: For row crops, measure a set length (like 10 feet). For broadcast crops, measure a square meter or other fixed area.
Count the Plants: Count the number of plants in the measured area. Note any gaps where plants are missing.
Record Your Counts: Write down your counts or enter them into a mobile app.
Calculate Plant Density: If needed, calculate the average number of plants per area. For rows, use:
\text{Plant Density} = \frac{\text{Total Number of Plants}}{\text{Total Length of Rows Sampled}}
]For broadcast crops, it’s usually per square meter or acre.
Analyze the Results: Compare your counts to the expected numbers to see how well your crops are growing.
