Hi -
Can anyone tell me what is the shortest trigger interval they are able to get from an Inspire 1 Pro using the capture app? (JPEG only, fast SD card)
I need to do high resolution, high overlap surveys of vegetation and another mapping app I have installed only allows for one image every four seconds.
Thanks!
Hi Robert,
Have you tried Pix4Dcapture on Android or iOS?
We have a getting started to help in case your are not familiar yet.
In our app it is possible to set the overlap up to 90-95%.
You can calculate the corresponding trigger interval following this article if you know the camera resolution in pixels and the ground sampling distance you want to achieve (pixel size that correspond to reality in cm):
https://support.pix4d.com/hc/en-us/articles/202557479
Let us know if we may further help.
