Deleted Camera Parameters File Settings PC. Operator error. what is the File we should never touch? Unable to import data from SD Card. Thank you.
You can find the Camera parameters file in: https://support.pix4d.com/hc/en-us/articles/360039273312-Your-camera-is-not-supported-at-this-time-PIX4Dreact
You can download it again and attach it to PIX4Dreact.
About unable to import data from SD card, please move all the images to your local computer before processing.
José
Mr. José, Thank you for your help. I’ll give it a try. It was working with the M30 prior to me deleting the file. Presently uninstalling React, download again. Doesn’t work, try your suggestion.
Thank
What error do you see?
click select file, and select the XML file you just downloaded from the article…
