camera not supported - raw2jpg export in adobe lightroom
Hello. I tried directly jpg files from DJI Air2s and it works with Pix4d React. Since I always work with raw files, I edit the contrast, noise wb, etc in Adobe Lightroom and exported to jpg with geotags. Now the React does not work with these files. Last year I used the Mapper and same files worked.
I do not change the resolution or any lens correction. I tried to edit the xml file but without any sucess. Can I send you some exported images?
Thank you.
It is not recommended to edit the image in any post-processing software.
The metadata might have changed and that is the reason why PIX4Dreact can’t read the images anymore.
You can share a few images in case it works with the XML.
José
Thank you for your response. Some images in the link bellow.
https://drive.google.com/drive/folders/1JwkzcWAvjBkKAUfqNucZ5sGKTbcQv86H?usp=drive_link
Thank your sharing the images. Images exif tags were changed indeed. I added the new camera name on the XML of https://support.pix4d.com/hc/en-us/articles/360039273312-Your-camera-is-not-supported-at-this-time-PIX4Dreact
Give it a try.
José
Hallo.I am also using Air2S and Lightroom.
I can’t merge images after image correction in Lightroom.
I cannot merge images using CustomCameraParameterFile_01032024.
Can you please create custom camera parameter file ?
https://drive.google.com/drive/folders/1lrEb1ScpZymLukEaRctUwGaKMe1xYta8?usp=sharing
hi,
Please process the raw imagery into PIX4Dreact.
Jose
