Questions about failed step
While working on step 2. point cloud and mesh, I received the following errors in the log (see below). I have been struggling to find out what these errors mean and was hoping someone on here might be able to give me some answers. Thank You!
[Info]: Generating texture atlas tiles [656/1152] elapsed 03m:10s:670ms …
[Info]: Mesh: local mask loaded for camera 654
[Error]: Invalid mask size
[Error]: Generating texture atlas tiles failed!
[Error]: \>\>\>Generating texture atlas tiles\<\<\< failed with error (failed to run a step!)!
[Error]: Error e0801: Generating Texture tiles failed.
[Processing]: Substep Dense mesh texture atlas tile finished.
[Error]: Failed to generate 3D textured mesh
[Info]: OS Power Save: Enable
[Info]: \>\>\>Step2\<\<\< done in 04h:07m:11s:048ms / 247.184 min.
Hi Joseph,
To have a better understanding of what is going on with the project I would like to ask you for additional data. Could you please send us the following?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
Thanks!
I have almost the same problem, could you help me?
 ![](https://support.pix4d.com/hc/user_images/_7aW2BfiRbno68fiONe4vg.png)
Ludwig Mathilda,
Can you tell me how to solve  the error shown below?
Hi Ludwig,
I can help you investigate the issue. However, could you first upload the following files so we have a better overview of your processing?
You can store the files in our OneDrive.
Thank you in advance
