I try to do Project, Iuse Pix4dmapper Pro. This project I’m testing iI have already tried once whitout no problems. When I would try it again, i got error message. The first step is going well, But when the secound stage comes i get error messages.
Is says : “Error: Failed to generated 3D textured mesh”
I have tired to do different projekt and all got the same error message.
the projekt is aerial mapping, and it is about 300-500 image
Same problem here. I processed a batch and the results were ok.
I tried to process again the same batch (same set of pictures, no change at all) and i got error:
[Processing]: Exporting 3D Mesh
[Error]: Failed to generate texture to \</Users/miguelistan/Desktop/fotogrametría/catedral\_2017.05.05/catedral alta/2\_densification/3d\_mesh/catedral alta\_texture.jpg\>
[Error]: Exporting 3D Mesh failed!
[Error]: \>\>\>Exporting 3D Mesh\<\<\< failed with error (failed to run a step!)!
[Error]: Failed to generate 3D textured mesh
[Processing]: Substep Dense mesh texture atlas tile finished.
This is not about camera calibration, this is a software issue.
It might be that you ran out of RAM. The software requires to have at least 4GB of RAM available for processing. We would recommend rebooting the computer (to clear the RAM) and trying to process again (just step 2).
Your project is located on a folder that contains special characters that are not recognized when reading the texture file.
This lead to the crash you experienced.
The solution would be to move (or save as in another folder) your project in a folder that does not contain any special characters.
Hope that this will solve your issue.
[Error]: Failed to generate texture to <C:/Drone Projects/Eagle Heights Ph 2 082221/2_densification/3d_mesh/Eagle Heights Ph 2 082221_texture.jpg>
[Error]: Exporting 3D mesh failed!
[Error]: >>>Exporting 3D mesh<<< failed with error (failed to run a step!)!
[Warning]: Warning w9020: GDAL Error <4> C:/Drone Projects/Eagle Heights Ph 2 082221/1_initial/project_data/thumbnails/DJI_0001_512.jpg: No such file or directory
I’m using a legion laptop i7 9th gen with 32 GB Ram and an RTX 2060 GPU. Never had an issue processing before. Tried adjusting the shutter, resetting the laptop to free up ram and changing the name to not include special characters. Also re-flew the project to make sure the pictures were all good. It has them all in the right geolocation and they seem to be stitching together correctly from the outline that remains. Can’t personally find any issue with the pics. Not sure what else to do .
So I did that and this is what I got. I do now have a fully stitched together picture of the area. Processing: Substep Dense mesh texture coordinates finished.
I do not. Just got the densified point cloud into an actual picture. The 3d texture mesh still fails out every time
UPDATE: I fixed the issue. I disabled my video card and uninstalled my drivers truned off my antivirus then reinstalled and rebooted everything. Seems to be working now.
PS: The 3 reply limit on this board for new users is idiotic.
