Not sure if this helps. Thank you for taking a look
[Warning]: TileGenerator: Skipping empty cluster
[Error]: Generating tiles failed!
[Error]: >>>Generating tiles<<< failed with error (failed to run a step!)!
[Error]: Processing group group1 failed!
[Error]: >>>Processing group group1<<< failed with error (failed to run a step!)!
[Error]: Dense Processing failed!
[Error]: >>>Dense Processing<<< failed with error (failed to run a step!)!
[Error]: Dense matching failed!
[Error]: >>>Dense matching<<< failed with error (failed to run a step!)!
[Processing]: Substep Dense matching finished.
<?xml version=“1.0” encoding=“UTF-8”?>
<report processed=" 2018-06-14 12:44:38" project=" Manchester 676"><system><cpu infoVerbose=“Intel(R) Core™ i7-6700 CPU @ 3.40GHz, cpus=1, threads=8” info=“Intel(R) Core™ i7-6700 CPU @ 3.40GHz” sse42=" true" sse3=" true" popcnt=" true" threads=" 8" sockets=" 1"/><ram units=" GB" capacity=" 32"/><gpuList><gpu displays=" 2" glFlags=" 3" glVersion=" 1" memoryBytes=" 2147483648" chipType=“AMD Radeon Graphics Processor (0x6610)” version=" 15.200.1055.0" provider=" Advanced Micro Devices, Inc." name=“AMD Radeon™ R5 340X” key=" \Registry\Machine\System\CurrentControlSet\Control\Video{9B5E10B0-D52F-11E7-9E23-484D7EC770F2}\0000"/><gpu displays=" 2" glFlags=" 3" glVersion=" 1" memoryBytes=" 2147483648" chipType=“AMD Radeon Graphics Processor (0x6610)” version=" 15.200.1055.0" provider=" Advanced Micro Devices, Inc." name=“AMD Radeon™ R5 340X” key=" \Registry\Machine\System\CurrentControlSet\Control\Video{9B5E10A7-D52F-11E7-9E23-9003B8965572}\0000"/></gpuList><os info=" Windows 10 Enterprise, 64-bit" platform=" windows"/></system><software><projectVersion>4.2.27</projectVersion><p4dVersion>19</p4dVersion><cameraModelVersion>19</cameraModelVersion></software><coordinateSystem><images><horizontal linearUnits=" m" wkt=" WGS84" wktVerbose=“GEOGCS[“WGS 84”,DATUM[“WGS_1984”,SPHEROID[“WGS 84”,6378137,298.257223563,AUTHORITY[“EPSG”,“7030”]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.01745329251994328,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4326”]]”/><vertical name=" egm96" geoidHeight=" 0" altitudeReference=" egm96"/></images><gcp><horizontal linearUnits=" m" wkt=" WGS 84 / UTM zone 19N" wktVerbose=“PROJCS[“WGS 84 / UTM zone 19N”,GEOGCS[“WGS 84”,DATUM[“WGS_1984”,SPHEROID[“WGS 84”,6378137,298.257223563,AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.0174532925199433,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Transverse_Mercator”],PARAMETER[“latitude_of_origin”,0],PARAMETER[“central_meridian”,-69],PARAMETER[“scale_factor”,0.9996],PARAMETER[“false_easting”,500000],PARAMETER[“false_northing”,0],UNIT[“metre”,1,AUTHORITY[“EPSG”,“9001”]],AXIS[“Easting”,EAST],AXIS[“Northing”,NORTH],AUTHORITY[“EPSG”,“32619”]]”/><vertical name=" egm96" geoidHeight=" 0" altitudeReference=" egm96"/></gcp><output><horizontal linearUnits=" m" wkt=" WGS 84 / UTM zone 19N" wktVerbose=“PROJCS[“WGS 84 / UTM zone 19N”,GEOGCS[“WGS 84”,DATUM[“WGS_1984”,SPHEROID[“WGS 84”,6378137,298.257223563,AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.0174532925199433,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Transverse_Mercator”],PARAMETER[“latitude_of_origin”,0],PARAMETER[“central_meridian”,-69],PARAMETER[“scale_factor”,0.9996],PARAMETER[“false_easting”,500000],PARAMETER[“false_northing”,0],UNIT[“metre”,1,AUTHORITY[“EPSG”,“9001”]],AXIS[“Easting”,EAST],AXIS[“Northing”,NORTH],AUTHORITY[“EPSG”,“32619”]]”/><vertical name=" egm96" geoidHeight=" 0" altitudeReference=" egm96"/><xyzMean z=" 81" y=" 4760479" x=" 303378"/></output><siteCalibration enabled=" false"><horizontal linearUnits=" m" wkt=" WGS 84 / UTM zone 19N" wktVerbose=“PROJCS[“WGS 84 / UTM zone 19N”,GEOGCS[“WGS 84”,DATUM[“WGS_1984”,SPHEROID[“WGS 84”,6378137,298.257223563,AUTHORITY[“EPSG”,“7030”]],AUTHORITY[“EPSG”,“6326”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.0174532925199433,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4326”]],PROJECTION[“Transverse_Mercator”],PARAMETER[“latitude_of_origin”,0],PARAMETER[“central_meridian”,-69],PARAMETER[“scale_factor”,0.9996],PARAMETER[“false_easting”,500000],PARAMETER[“false_northing”,0],UNIT[“metre”,1,AUTHORITY[“EPSG”,“9001”]],AXIS[“Easting”,EAST],AXIS[“Northing”,NORTH],AUTHORITY[“EPSG”,“32619”]]”/><vertical name=" egm96" geoidHeight=" 0" altitudeReference=" egm96"/><rigidTransform scale=" 1"><translation z=" 0" y=" 0" x=" 0"/><rotation kappa=" 0" phi=" 0" omega=" 3.1415926536"><eulerAngles z=" 0" y=" 0" x=" 0"/></rotation></rigidTransform></siteCalibration></coordinateSystem><options><initial><runStep>true</runStep>
<!-- General –>
<!–Keypoints Image Scale–>
<keypointsImageScale>Full</keypointsImageScale><imageScale>1</imageScale>
<!–Quality report–>
<generateOrthoInReport>true</generateOrthoInReport>
<!-- Matching –>
<!–Matching Image Pairs–>
<matchStrategy>AutoAerial</matchStrategy><matchTimeNbNeighbours>1</matchTimeNbNeighbours><matchUseTriangulation>true</matchUseTriangulation><matchRelativeDistanceImages>0</matchRelativeDistanceImages><matchMtpMaxImagePair>5</matchMtpMaxImagePair><matchImageSimilarityMaxPairs>1</matchImageSimilarityMaxPairs><matchTimeMultiCamera>0</matchTimeMultiCamera>
<!–Matching Strategy–>
<geometricallyVerifiedMatching>false</geometricallyVerifiedMatching>
<!-- Calibration –>
<!–Targeted number of keypoints–>
<keypointSelectionMethod>Automatic</keypointSelectionMethod><numberOfKeypoints>10000</numberOfKeypoints>
<!–Method–>
<calibrationMethod>Standard</calibrationMethod>
<!–Optimizer–>
<optimizerType>Ceres</optimizerType>
<!–Camera optimization–>
<internalParamOptimization>All</internalParamOptimization><externalParamOptimization>All</externalParamOptimization><leverarmParamOptimization>None</leverarmParamOptimization>
<!–Rematch–>
<rematchStrategy>Auto</rematchStrategy><rematch>false</rematch><rematchOverlap>0.3000000119</rematchOverlap>
<!–SkySegmentation–>
<automaticSkyMasking>true</automaticSkyMasking>
<!–Export–>
<exportCameraParamsAATBBA>true</exportCameraParamsAATBBA><exportUndistortedImages>false</exportUndistortedImages>
<!-- Miscellaneous options –>
<matchAll>false</matchAll><targetCameraDist>0</targetCameraDist><descriptorType>0</descriptorType><minImageDist>1.6289774941</minImageDist><rigMatch>true</rigMatch><saveKMLReport>false</saveKMLReport><createThumbnails>true</createThumbnails><threshAdd>20</threshAdd><threshHom>10</threshHom></initial></options><results><initial><gsd inches=" 0.441791816399217" cm=" 1.12215121365401"/><trackHistogram numberOf3DPoints=" 782988" observed2DPoints=" 2266297"><bin points3D=" 498540" images=" 2"/><bin points3D=" 141265" images=" 3"/><bin points3D=" 60174" images=" 4"/><bin points3D=" 30405" images=" 5"/><bin points3D=" 16835" images=" 6"/><bin points3D=" 10469" images=" 7"/><bin points3D=" 7124" images=" 8"/><bin points3D=" 4895" images=" 9"/><bin points3D=" 3349" images=" 10"/><bin points3D=" 2396" images=" 11"/><bin points3D=" 1770" images=" 12"/><bin points3D=" 1237" images=" 13"/><bin points3D=" 962" images=" 14"/><bin points3D=" 792" images=" 15"/><bin points3D=" 591" images=" 16"/><bin points3D=" 454" images=" 17"/><bin points3D=" 343" images=" 18"/><bin points3D=" 265" images=" 19"/><bin points3D=" 215" images=" 20"/><bin points3D=" 186" images=" 21"/><bin points3D=" 161" images=" 22"/><bin points3D=" 105" images=" 23"/><bin points3D=" 78" images=" 24"/><bin points3D=" 87" images=" 25"/><bin points3D=" 71" images=" 26"/><bin points3D=" 57" images=" 27"/><bin points3D=" 40" images=" 28"/><bin points3D=" 46" images=" 29"/><bin points3D=" 20" images=" 30"/><bin points3D=" 18" images=" 31"/><bin points3D=" 20" images=" 32"/><bin points3D=" 6" images=" 33"/><bin points3D=" 4" images=" 34"/><bin points3D=" 6" images=" 35"/><bin points3D=" 2" images=" 36"/></trackHistogram><points2D><general><keypoints><distribution median=" 25660" mean=" 32953" min=" 18420" max=" 79233"/></keypoints><tracks><distribution median=" 3090" mean=" 3348" min=" 28" max=" 15931"/></tracks></general></points2D><images disabled=" 0" enabled=" 713" calibratedGeolocated=" 677" geolocated=" 713" calibratedPercentage=" 94" calibratedEnabled=" 677" calibrated=" 677" total=" 713"/><cameraOptimization relativeDifference=" 0.76"/><qualityStatus images=" success" georeferencing=" warning" matching=" success" cameraOptimization=" success" dataset=" warning"/><atps meanProjectionError=" 0.2092"/><general time=“”/><statsControlPoints><gcps><avgPixel>0</avgPixel><inliers/><outliers/></gcps><checkPoints><avgPixel>0</avgPixel><inliers/><outliers/></checkPoints><manualTiePoints><avgPixel>0</avgPixel></manualTiePoints></statsControlPoints><camera name=“FC220_4.7_4000x3000 (RGB)” uniqueName=“FC220_4.7_4000x3000 (RGB)(2)”><id>1</id><band name=" Red" weight=" 0.2126" width=" 0" centralWaveLength=" 660"/><band name=" Green" weight=" 0.7152" width=" 0" centralWaveLength=" 550"/><band name=" Blue" weight=" 0.0722" width=" 0" centralWaveLength=" 470"/><serialNumber/><initialValues><imageWidth>4000</imageWidth><imageHeight>3000</imageHeight><pixelSize>1.58173</pixelSize><principalPointXmm>3.033426</principalPointXmm><principalPointYmm>2.350134</principalPointYmm><lensType>perspective</lensType><focalLengthmm>4.8613</focalLengthmm><distortion>5</distortion><radialK1>0.032984</radialK1><radialK2>-0.085597</radialK2><radialK3>0.077778</radialK3><tangentialT1>0.00041</tangentialT1><tangentialT2>-0.000807</tangentialT2><cameraModelSource>internalDB</cameraModelSource><principalPointXPixel>1917.8</principalPointXPixel><principalPointYPixel>1485.8</principalPointYPixel></initialValues><optimizedValues><imageWidth>4000</imageWidth><imageHeight>3000</imageHeight><pixelSize>1.58173</pixelSize><principalPointXmm>3.120792</principalPointXmm><principalPointYmm>2.387168</principalPointYmm><lensType>perspective</lensType><focalLengthmm>4.8242</focalLengthmm><distortion>5</distortion><radialK1>0.057133</radialK1><radialK2>-0.128112</radialK2><radialK3>0.115136</radialK3><tangentialT1>0.000137</tangentialT1><tangentialT2>0.000522</tangentialT2><cameraModelSource>internalDB</cameraModelSource><principalPointXPixel>1973</principalPointXPixel><principalPointYPixel>1509.2</principalPointYPixel></optimizedValues><uncertainties><principalPointXPixel>0.2</principalPointXPixel><principalPointYPixel>0.2</principalPointYPixel><focalLengthmm>0.000528</focalLengthmm><radialK1>0.00022</radialK1><radialK2>0.000817</radialK2><radialK3>0.000911</radialK3><tangentialT1>0.000012</tangentialT1><tangentialT2>0.000015</tangentialT2></uncertainties></camera><resources><matchesLegend><bin name=" 25" intensity=" 230"/><bin name=" 222" intensity=" 227"/><bin name=" 444" intensity=" 199"/><bin name=" 666" intensity=" 170"/><bin name=" 888" intensity=" 142"/><bin name=" 1111" intensity=" 114"/><bin name=" 1333" intensity=" 85"/><bin name=" 1555" intensity=" 57"/><bin name=" 1777" intensity=" 29"/><bin name=" 2000" intensity=" 0"/></matchesLegend></resources></initial></results></report>
