I am using the Pix4Dmapper software for my UAV remote sensing image analysis. A 3-band multi-spectral camera was used. Also, GCPs were automatically detected by Pix4Dtagger.
Most of the projects finished with satisfying results, but some of them stopped with unexpected errors at the beginning of step 2. Could you teach me what should I do to solve the problem?
I am attaching the xml file of the project report (the log file cannot be uploaded perhaps due to its large size).
report.xml (559.0 KB)
The following is a part of the log file where the fatal error occurred:
[2021.01.07 22:48:58][ 46%RAM][ 9%CPU][Error]: Generating tiles failed!
[2021.01.07 22:48:58][ 46%RAM][ 9%CPU][Error]: >>>Generating tiles<<< failed with error (failed to run a step!)!
[2021.01.07 22:48:58][ 46%RAM][ 9%CPU][Error]: Processing group Green failed!
[2021.01.07 22:48:58][ 46%RAM][ 9%CPU][Error]: >>>Processing group Green<<< failed with error (failed to run a step!)!
[2021.01.07 22:48:59][ 46%RAM][ 16%CPU][Error]: Dense Processing failed!
[2021.01.07 22:48:59][ 46%RAM][ 16%CPU][Error]: >>>Dense Processing<<< failed with error (failed to run a step!)!
[2021.01.07 22:48:59][ 46%RAM][ 16%CPU][Error]: Dense matching failed!
[2021.01.07 22:48:59][ 46%RAM][ 16%CPU][Error]: >>>Dense matching<<< failed with error (failed to run a step!)!
