I have a corridor project using a DJI MavicPro. The initial processing looks good, but when I run step 2, it keeps failing with this message:
[Processing]: Substep Dense matching started.
[Processing]: Dense matching
[Processing]: Dense Processing
[Processing]: Checking cameras
[Processing]: Processing group group1
[Processing]: Group group1, cluster 1/1 : initializing 178 cameras
[Processing]: Group group1, cluster 1/1 : initializing 175015 points
[Processing]: Group group1, cluster 1/1 : optimizing 18694983 points [1/3]
[Processing]: Group group1, cluster 1/1 : optimizing 17252523 points [2/3]
[Processing]: Group group1, cluster 1/1 : optimizing 17137720 points [3/3]
[Processing]: Group group1, cluster 1/1 : finalizing 17065316 points
[Processing]: Group group1, cluster 1/1 : checking 17065316 points
[Processing]: Group group1, cluster 1/1 : coloring 17065316 points
[Processing]: Group group1, cluster 1/1 : writing 17065316 points
[Error]: ClusterProcessing: Error while writing points, normals, colors into P4B file \<Z:/Drawing Files/Pix4d Data/Gibbs - Kerr Redi Mix/Gibbs - Kerr Redi Mix Scene/temp/dense/Gibbs - Kerr Redi Mix Scene\_group1\_raw\_part\_1.tmp\>
[Error]: Failed to write cluster P4B file \<Z:/Drawing Files/Pix4d Data/Gibbs - Kerr Redi Mix/Gibbs - Kerr Redi Mix Scene/temp/dense/Gibbs - Kerr Redi Mix Scene\_group1\_raw\_part\_1.tmp\>
[Warning]: GroupProcessing: No dense points were created from cluster 0
[Processing]: Group group1, 1 cluster(s) processed, 0 points
[Processing]: Generating tiles
[Error]: TileGenerator: Failed to create raw tile 0
[Error]: Generating tiles failed!
[Error]: \>\>\>Generating tiles\<\<\< failed with error (failed to run a step!)!
[Error]: Processing group group1 failed!
[Error]: \>\>\>Processing group group1\<\<\< failed with error (failed to run a step!)!
[Error]: Dense Processing failed!
[Error]: \>\>\>Dense Processing\<\<\< failed with error (failed to run a step!)!
[Error]: Dense matching failed!
[Error]: \>\>\>Dense matching\<\<\< failed with error (failed to run a step!)!
Any thoughts on how to fix this or what is wrong? I've never had this issue before.
