My problem is a little bit strange, 1 step is finished normally, without errors, 2 step crash almost at the end of processing. What is wrong with this? Photos from Sony alpha 6000, GSD 1 cm, good overlap 50/70%.
[UI]: Show Quality Report clicked.
[UI]: Save Project clicked.
[UI]: Processing Options clicked.
Processing: Substep Dense matching started.
Processing: Dense matching
Processing: Dense Processing
Processing: Checking cameras
Processing: Processing group group1
Processing: Group group1, cluster 1 : initializing 91 cameras
Processing: Group group1, cluster 1 : initializing 154546 points
Processing: Group group1, cluster 1 : optimizing 16363647 points [1/3]
Processing: Group group1, cluster 1 : optimizing 15611799 points [2/3]
Processing: Group group1, cluster 1 : optimizing 15136883 points [3/3]
Processing: Group group1, cluster 1 : finalizing 15049843 points
Processing: Group group1, cluster 1 : checking 15049843 points
[Error]: Error while writing camera indices into file <R:\Drony\02_Projekty\04_Pix4D\projekty/wn_5/temp/dense/wn_5_group1_data_part_1.tmp>
[Error]: Failed to write cluster Vis file <R:\Drony\02_Projekty\04_Pix4D\projekty/wn_5/temp/dense/wn_5_group1_data_part_1.tmp>
[Error]: Processing group group1 failed!
[Error]: >>>Processing group group1<<< failed with error (failed to run a step!)!
[Error]: Dense Processing failed!
[Error]: >>>Dense Processing<<< failed with error (failed to run a step!)!
[Error]: Dense matching failed!
[Error]: >>>Dense matching<<< failed with error (failed to run a step!)!
Processing: Substep Dense matching finished.
