processing error - really wierd
Working on my first project and I am getting a processing error.  80 images collected with a Phantom 4 (latest firmware). When I go to process in Pix4dmapper it won’t process.(ver 2.1.53 64bit).
the images are of farm fields, forest, few buildings.
The log file says it can’t write to the C drive and then says “no error”
Any ideas - log below
[UI]: New Project clicked.
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/result_cameras_full_1.p4b: No error
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/result_gcps_full_1.p4b: No error
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/coord_systems_full_1.p4b: No error
Processing: Substep Keypoint extraction started.
Processing: Gather image information
Processing: Generate normalized/thumbnail images
Processing: Computing keypoints
[Error]: Writing features: failed to open <C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/feat_full_1.p4b> file: No error
Processing: Substep Keypoint extraction finished.
Processing: Substep Keypoint matching started.
Processing: Generating pairs
Processing: Computing matches
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/mat_full_1.p4b: No error
Processing: Initialize automatic tie points.
Processing: Building automatic tie points.
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/init_tracks_full_1.p4b: No error
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/init_cameras_full_1.p4b: No error
Processing: Substep Keypoint matching finished.
Processing: Substep Camera calibration started.
Processing: Analyse automatic tie points.
Processing: Compute number of matches.
Processing: Initialize calibration
[Warning]: Unable to write C:\Users\Eric\Desktop\Documents//test/1_initial/project_data/result_clusters_full_1.p4b_000.p4drec: Domain error
[Error]: no blocks computed
[Error]: No calibrated cameras.
[Error]: C:\Users\Eric\Desktop\Documents//test/1_initial/report/html//report_links.xml: could not open file
Processing: Substep Camera calibration finished.
Processing: Substep Report generation started.
[Error]: Cannot compute the average ground sampling distance (GSD).
[Error]: Error e0046: Processing failed. Cannot compute the average ground sampling distance (GSD).
Processing: Substep Report generation finished.
[UI]: Processing Options clicked.
Eric,
I also got this error. I didn’t have good overlap.
check this:
https://support.pix4d.com/hc/en-us/articles/204542375-Error-e0046-Processing-failed-Cannot-compute-the-average-ground-sampling-distance-GSD
Max.
hi Pix4d support,
ive a same problem which is cannot doing processing for my data. Below is the example of the warning error from pix4d. Please give some advise about this.
[Processing]: Compute number of matches.
[Processing]: Substep Georeference the model finished.
[Processing]: Substep Camera calibration started.
[Processing]: Substep Camera calibration finished.
[Error]: Caught unknown exception during initial processing!
[Info]: OS Power Save: Enable
[Info]: \>\>\>Step1\<\<\< done in 13s:771ms / 0.229517 min.
[Processing]: ProjectLoaded
[Info]: DataProvider: closing
[Info]: Project results: loading ...
[Info]: Project: Cameras updated
[Info]: Project: Cameras loaded
[Info]: Project: Calibrated tracks loaded
[Info]: Project: loading done.
[Info]: Time spent building the tree: 000ms, total number of points = 2552
[Info]: Finished loading tracks layer with 2552 points
 ![](https://support.pix4d.com/hc/user_images/EzICvjNMpY-TFI5_mMgSfA.png)
We would need more details to provide assistance in the most efficient way.
Can I ask you to submit a request to Pix4D Support with the following files?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf
▸ The project file (.p4d): …\project_name.p4d
Additionally, please send us the machine specs:
  1. Click the Windows Start icon and type System Information. Select the application in the list above.
  2. In the application, click File > Save… and export the content.
  3. Attach the file your_file.nfo to the reply.
Thank you in advance!
Hello Pix4D support,
i have a same problem which is cannot doing processing warning error from pix4d.
[Error]: Caught exception during initial processing!
Hi @test.dem100563
Can you please share the project log file with us?
It would be very helpful for us to look at the log altogether.
You can also find the instruction here on how to find the log file.
Menu View > Log Output
Thank you.
Sincerely,
Rosana
Can i please ask. What was the problem and solution?
Hi @vinkienz
Welcome to Pix4D Community!
We need the information to be able to help you with this issue.
  • Can you please describe us the steps you followed before you get this warning?
  • Did you manage to open the project or did it fail?
  • Could you please send us a screenshot the moment the error occurs?
  • Could you please access the 1_initial folder? Are all the files properly generated?
We suspect that there might be a problem with the memory allocation.
Please could you give us more information about the hardware of your notebook?
  • How much RAM memory:
  • What is the GPU:
  • What is the CPU:
  • Available hard disk space:
Could you also send us the full log file (.txt file) that you will find in the results folder, as you can see in the screenshot below:
Have a very nice day!
Best regards
