Mapper processing failure
Got a whole host off errors in processing this project.
[Error]:  ClusterProcessing: Error while writing points, normals, colors into P4B file <T:/4492 Inland Propane/PIX4D/4492 Inland Propane/4492 Inland Propane/temp/dense/4492 Inland Propane_group1_raw_part_1.tmp>
[Error]: Failed to write cluster P4B file <T:/4492 Inland Propane/PIX4D/4492 Inland Propane/4492 Inland Propane/temp/dense/4492 Inland Propane_group1_raw_part_1.tmp>
[Error]: TileGenerator: Failed to create raw tile 0
[Error]: Generating tiles failed!
[Error]: \>\>\>Generating tiles\<\<\< failed with error (failed to run a step!)!
SOLVED!
I was using the software locally but reading and writing to a network drive.  I moved all of the files locally and everything worked.
That’s great Rudy. Thanks for posting your issue and the solution for our users :slight_smile:
