No dense points were created from cluster 0 - Generating tiles failed!
Processing of Step2 stops almost immediately with an error.  Here is the log snippet.
[Processing]: Substep Dense matching started.
[Processing]: Dense matching
[Processing]: Dense Processing
[Processing]: Checking cameras
[Processing]: Processing group group1
[Processing]: Group group1, cluster 1/1 : initializing 142 cameras
[Processing]: Group group1, cluster 1/1 : initializing 16561 points
[Warning]: Group group1, cluster 1/1 : no point initialized
[Warning]: No dense points were created from cluster 0
[Processing]: Generating tiles
[Warning]: Skipping empty cluster
[Error]: Generating tiles failed!
[Error]: \>\>\>Generating tiles\<\<\< failed with error (failed to run a step!)!
[Error]: Processing group group1 failed!
[Error]: \>\>\>Processing group group1\<\<\< failed with error (failed to run a step!)!
[Error]: Dense Processing failed!
[Error]: \>\>\>Dense Processing\<\<\< failed with error (failed to run a step!)!
[Error]: Dense matching failed!
[Error]: \>\>\>Dense matching\<\<\< failed with error (failed to run a step!)!
[Processing]: Substep Dense matching finished.
Hi Brad,
Could you please send a request to Support and attach the quality report and log file so that we can advise?
https://support.pix4d.com/hc/en-us/articles/hc/en-us/requests/new
Did you figure out where the error comes from? Could you solve it?
I am facing the same issue (exact same log output)
Below a few screenshots of my sparse point cloud and quality report.
Thanks a lot!
Hello Nicolas,
The Dense Matching error can be attributed to different reasons, usually hardware related.
To better understand your issue you can send a Support request at: https://support.pix4d.com/hc/en-us/articles/hc/en-us/requests/new, including the following:
-log file
-Quality Report
-version of Pix4Dmapper installed
-PC configuration (RAM, CPU, GPU, Hard disc space)
