I have a dataset of radiometric thermal images that I have successfully processed into an orthophotomosaic.
Unfortunately even though the temperatures of the source dataset exceed 150 degrees, the finished tiff only shows temperatures of up to 150° C.
Is there a way to set the temperature range in the processing options or anything else I can do to preserve the original temperature range?
Best thanks and regards
Ben
