Hi, we have run several flights’ worth of images through FLIR Thermal Studio Pro to change certain camera parameters (emissivity, apparent reflected temperature, ambient temperature and relative humidity) as a post-processing step. The original images orthomosaic just fine with Pix4Dmapper, but once they’ve been processed in FLIR Thermal, the orthomosaic processing is a mess. I have tried fixing the issue by checking the EXIF information, and geolocating the processed thermal images again, but cannot find why this may be happening. I can make these images available to you if needed. Your help would be greatly appreciated!
Hi Natalie, I have replied to your personal support request asking for the images. We/you can update the post after troubleshooting the issue.
Hi, thanks so much but we have resolved the issue- the camera name/version was being read in incorrectly. Afte changing this, the stitching works much better. Thanks so much
