Thermal Orthomosaics
I currently have a DJI XTR camera and use it to take Thermal Images. In Pix4D how can I get a temperature scale for the reflectance map created?
Hi Aswin,
Have you tried the workflow described here:
Ina
This link is not opening, Can you give the new link for the above query?
Hi @supportrly,
I have updated the link.
Sorry for the inconvenience.
Best
Hey, Marco!
  1. Currently, Pix4D users cannot change temperature indexes for 3D networks and point clouds. I want to get such elevation as in the Index Map. Are such updates planned?
  2. When I make a convenient index map, I set the interval to 50-150 'C and get a GENIUS\BEAUTY\IDEAL image. She combined my Index Map and orthopaedic. I see: 1) my object and 2) the temperature range I need.
But! I can 't take that image. You can export a 3d grid or index map only individually.
I think that at the moment the Pix4D mapper is unable to export this together. If I 'm wrong, please tell me, how can I get this image?
I believe developers can make changes and add such a tool.
  1. Where does orthomoshik come from if its tab is not active and you cannot get it for thermal images?
Respect you very much, thank you!! image|690x297
