I have 32 bit TIFFs that contain actual temperature values in degrees C. Pix4d seems to stretch the values for display and then writes duplicates those values to RGB. I am hoping for a solution so that the original values would be kept in the resulting point cloud. Thanks!
Dear Jean,
If your values are already in Celsius, you might want to turn off the normalization:
https://support.pix4d.com/hc/en-us/articles/202559509
If this does not solve your issue, please send us your project log file and the quality report at support@pix4d.com, mentioning this forum post.
