Processing failed. Generating grayscale normalized image
Hi pix4d team,
I am using Geotiff images and trying to generate a mosaic from the aerial images I have. However, I keep getting this error. Apparently pix4d is trying to build temp files but doesn’t have access to the files it makes! any solution?
e0046: Processing failed. Generating grayscale normalized image: cannot open image C:/Users/ah7557/Desktop/temp1/1_initial/project_data/normalised/L2_SRF_AARR_IMG_0039_1.jpg for writing. No such file or directory.
Hi @pix4d3
Are you trying to process thermal images?
Could you please describe your whole workflow?
(Flight plan, camera/drone used/processing option)
Could also please attach to your reply the *.log file?
Best
Any hope on this?
I am new to pix4D, I am trying the trial version.
It doesn’t seem to recognize my camera (I use DJI Matrice600’s hyperspectral camera).
I have same error as the above.
Hello @dhelmanlab, I would suggest you to go through the below support article on
