I´ve tried to processing a project just with iPhone pictures and at the logout show the next:
[Warning]: No initial frame
[Error]: no blocks computed
[Processing]: Substep Camera calibration finished.
[Error]: No calibrated cameras.
[Processing]: Substep Report generation started.
[Processing]: Read keypoints.
[Processing]: Substep Report generation finished.
[Error]: Error e0046: Processing failed. No calibrated cameras.
[Processing]: ProjectLoaded
What Have I do to solve this problem?
Hello Team, I am facing the same issue. I have used burst mode photos and I am getting the same error.
[Processing]: ProjectLoading
[Warning]: Warning w9020: GDAL Error <1> latitude or longitude exceeded limits
[Warning]: Warning w0032: Results for this project are already generated. By starting the processing again existing results will be overwritten.
[UI]: Processing Start clicked.
[Processing]: Step1Running
[Processing]: Substep Keypoint extraction started.
[Processing]: Analyse Keypoints.
[Processing]: Substep Keypoint extraction finished.
[Processing]: Substep Keypoint matching started.
[Processing]: Generating pairs
[Processing]: Read matches.
[Processing]: Write matches.
[Processing]: Substep Keypoint matching finished.
[Processing]: Initialize automatic tie points.
[Processing]: Building automatic tie points.
[Processing]: Substep Camera calibration started.
[Processing]: Analyse automatic tie points.
[Processing]: Compute number of matches.
[Processing]: Initialize calibration
[Processing]: Calibrate
All the photos have GPS tag and was clicked from iphone 6s back camera.
Please, guide me which settings/ configuration I need to use to solve this issue.
