Would it be possible to have the capture app let you chose the speed in MPH not slow to fast?
Hi Erik,
Since it is possible to change the flight altitude in the App, the speed is automatically adapted depending on the height of the mission. The higher the mission, the faster the drone.
When the speed of the drone is set to fast the drone will fly faster but slow enough so to that the drone will be able to take enough images which is limited by the number of images that the drone can take per second and also for connectivity reasons between the drone and the App.
The speed is also adapted to minimize the potential blurry effect of images. If you fly at very low altitude and with a very high speed you might obtain more blurry images.
It’s possible to change the speed between slow and fast to make the app easier and to avoid flying too fast or too slow for a low or high mission.
