Hi!
I can’t understand what I’m doing wrong.
Mavic 2 pro
Auto take photo mode
Pix3dCapture
Mission 80% overlap
Speed 4 m/s
Elevation from ground 50
85 photos.
Wthout GCP
Result - Poor and abnormal ortomosaique quality.
Any idea?
You should be able to set your GSD as required. I downloaded your data and tried processing using the 2cm GSD and there was no issue. I would suggest you reprocess your project from step 1 and see if that helps to solve your issue.
Hi, I figured out the first object using your tips - the result is as good as you in 2 cm, but look at the second object, I put all the necessary information in the cloud. There again, it turned out very qualitatively. https://drive.google.com/drive/folders/1Xe225RhrKEL1NZJPTVfEuqEyjKs7XW3e
Here is the result obtained using the settings in steps 1,2,3.
Check with yourself, I would like to understand what is the reason.
Photos are a little dark, but they should not affect the quality of orthophotomap.
