Sometimes I have some problems with the generation of the orthomosaic when I select the option “Resolution Automatic 2 x GSD”. The orthomosaic appears with some noise, but the problem is solved when I select the resolution automatic 1xGSD.
On the other hand, the same problem appears when I select the option “Custom” with some values of resolution, but not with other ones.
Indeed, what we can see looks quite odd… Did you try to check how the results look like in another third-party software, like for instance QGIS? To investigate if it is just a visual issue. Is it happening with other projects as well or only with this specific one?
Can I ask you to submit a request to Pix4D Support? We would need more details to investigate the issue properly.
Could you please send us the following?
▸ The quality report (.pdf format): …\project_name\1_initial\report\project_name_report.pdf (good and bad example)
▸ The project file (.p4d): …\project_name.p4d
▸ Several screenshots (as you already did)
you can also link this community post as a referece.
I am having exactly this issue. Orthomosaics created at 1x resolution are perfect. Orthomosaics created at other than 1x have this same issue. Is there a solution?
This is a known issue and it happens when the camera model is set to rolling shutter and the resolution of the DSM and orthmosaic os not “1x”.
There is no solution for now.
Are you using rolling shutter? In case so, I would try to not use it. Even if you use a rolling shutter camera, the effect does not always appear so the recommendation is using the standard camera model by default.
This community post contains a lot of information on how to use it.
Thank you very much.
Cookie Policy
