Pointcloud visualisation issues (Inconsistent Point Cloud Rendering in Pix4Dmatic, noticeable since v1.78)
Hello dear Pix4D team,
Since version 1.79 I have noticed an issue with the point cloud rendering. The points are no longer displayed consistently in size. Even if I adjust the sliders for point cloud size, the points remain uneven: along the edges, some points appear at least ten times larger than those in the center (see screenshot, red marker).
Please note: we are not looking at the automatic tie point cloud, but only at the dense point cloud (DPC).
When I rotate the model, the point sizes change again, which makes it really hard to focus and work precisely. As far as I know, this behavior did not exist before.
I kindly ask that the point cloud display is made uniform again (as it used to be and as is standard in other point cloud viewers), and that this bug is fixed as soon as possible.
Manuel Allinger
@Pierangelo_Rothenbuhler @Rhea_Garratt
I just found a setting in the Pix4Dmatic preferences/graphics: the Maximum Number of Points per Point Cloud for rendering. When I increase this value from the default 8 million to 100 million, the issue seems to disappear.
However, I would kindly ask you to check why the visualization looks so inconsistent at the other setting than max.
Could you please confirm whether this inconsistent behavior is intended, or if it should be considered a bug?
Thanks!
The described issue is only gone, when I slide it to 100 M. But then it starts lacking (RTX3090).
Please solve that. I would like to look at 10 million / 20 M / 50 M same sized points, what isn’t possible now :winking_face_with_tongue::wink:
Hello Manuel,
Thank you for reaching out. We’re looking into your request and will get back to you as soon as we have an update.
To help us, could you please let us know
  • What is the size of the point cloud in your project?
  • Are you using the projective or orthographic view?
Alexey
Hi, I observe the issue with all point sizes, no matter what I choose here. Normaly I go betweeen 3-5. Normally I use projective view.
Could you reporduce my issues on your side, so do you know what I’m arguing on? Or is it still unclear? Please reply
So, two weeks later….
Could you guys reproduce the behavior I did report? Anything?
Is it a well known bug in Matic? Will it be solved soon?
Hello Manuel,
Thank you for your message. Your observation relates directly to how PIX4Dmatic is designed to efficiently handle very large datasets.
To ensure smooth, flicker-free rendering, the point cloud is spatially partitioned and uses multiple levels of detail. This means that areas farther from the camera are intentionally displayed with a lower density of points. To compensate for this and prevent the point cloud from looking sparse or having gaps in the distance, we dynamically increase the size of these farther points. This technique keeps the visual density of the point cloud looking homogeneous. The effect you are observing is a direct result of this performance-enhancing feature.
The alternative would be to keep all points at a fixed size. However, this would likely cause a different visual artifact: you would see distinct borders between the levels of detail, and distant areas would appear “holey”, like on the image below:
We are considering adding an option for fixed-size points in a future release. Is this a feature you would be interested in?
In the meantime, you can indeed try increasing “Maximum number of points per point cloud” in Preferences > Graphics. This will render more points overall, which may reduce the sizing effect, but please be aware that it will also increase the demand on your hardware. You may need to experiment to find the optimal value for your specific system and project.
Kind regards,
Alexey
Hello Pix4D Team,
Thank you for your detailed response.
I fully understand the technical rationale for the dynamic point size adjustment and the use of multiple levels of detail. However, from a user’s perspective, this implementation feels quite unusual—and, at least for our daily workflow, a bit confusing too. We regularly use a range of other point cloud solutions, and this specific visual effect does not occur in any of them, afaik, even when working with very large datasets and fixed point sizes.
For our applications, the shifting and inconsistent point display actually makes precise work significantly more difficult and is visually distracting. Additionally, I would like to note that previous versions of Matic did not exhibit this behavior, which means this change has been very noticeable in our routine workflows.
To be candid, I would personally favor a more traditional rendering approach, even if it means distant areas appear less dense, in order to maintain a consistent point size. This consistency is crucial for both analysis and clear project presentations.
I appreciate your efforts to optimize performance and rendering, but I wanted to provide this direct feedback based on hands-on field use. If there are settings or future improvements planned to address this, I would be very interested to hear more.
Manuel Allinger
@andrea.dotti
@maal there are specific corner-case projects where we have indeed observed differences in point size even with the maximum points toggle set to 100M. Could you share a project so we can investigate it? I will contact you via email as well.
