Changing point size in the point cloud
I’m actually trying the pix4dsurvey software and when importing a .las the points loaded are very very very big. I would like to reduce it in order to make precise polygons …
Is there any way to do that ?
Regards
There is point size slider in the 3D view settings. You can find it in bottom left corner.
Hello together
Is it possible to adjust the point size for all point clouds at once? That would be very helpful. Currently I have a pix4dsurvey project with 10 different scans. This would make the work quite easier.
Thank you!
Hi @alain.freiburghaus,
You can modify the size of all the point clouds by opening the Project Settings image found at the top-right corner and then using the slider in the Point Size.
This will modify the size of all the point clouds in your project.
You can then modify single point clouds in the content sidebar on the left for fine-tuning your project.
Hope this helps :slight_smile: .
Hello
Embarrassing that I didn’t find this myself. This helps me a lot, thank you!
I’m happy to hear that the described feature is doing exactly what you were looking for.
Happy mapping!
