Does anyone know why im getting these different levels of resolution as i pan and zoom?
Its quite frustrating as im trying to vectorize and add lines with any detail. As soon as i move it may go away to the more coarse detail.
Ryan
Ryan
try increasing the point size in the settings.
that doesn’t seem have anything to do with the density or points displaying/disappearing tho.
my issue is the points dont show up untill i pan/zoom to a certain level and then they go away again if i move.
Hi @Ryan_Beisaw
What version of PIX4Dsurvey are you using?
Regards
At this moment, im running 1.76.0
I have downloaded the newest version and in the process of getting IT to install.
I don’t recall running into this issue in past projects or versions…
@Alvaro_Santiago
I have re-processed the job again to make sure there was no error in doing so, the same process i have used for years Matic–>Survey
Here is another shot of the clear difference in pavement. Obviously the left of the pic is ‘normal’ and the right side is all pixelated.
Hi @Ryan_Beisaw,
You need to increase the Max points per point cloud in Preferences -> Graphics. Let me know if changing this value solves the problem.
Regards
Yes! Thank you!
This must either be something new in the recent versions or just got reset back to minimum level. Appreciate the help.
Ryan B
