Hi, I have a dataset which includes a non-vegetated area in the center, surrounded by vegetation. (winter forest)
Using a minimum number of 3 matches, I get this result:
The center shows good results, the surrounding forest logically shows holes in the point cloud.
Therefore, it seems logical to reduce the minimum number of matches to 2, so that more of the forest ground will be densified (it is winter, so we can see a lot of the ground points).
By only reducing the minimum number of matches we get a lot more ground points on the forest. However, the “easy” center area is gone? How is this possible? I made no other changes to the processing options.
