RECENTLY PROCESSED A FLIGHT THAT GENERATED PLENTY OF POINT CLOUD DATA BUT THE MOSAIC DID NOT PROCESS IN THIS PARTICULAR AREA.
Would you please upload the quality report and screenshot of the results to understand the problem?
Kind regards,
NYRSTAR 9-15-21_report.pdf (1.4 MB)
thanks for the help so far
Thank you for uploading the files.
According to the quality report, the result could be improved if you lower the keypoints to 1/2 (Half image size). This processing option can lead to a higher number of calibrated images than the default original keypoint image scale. (For more information: Menu Process > Processing Options… > 1. Initial Processing > General.) Would you please try this setting, process step 1 and check the quality report?
No change.
Would you please upload the new quality report to evaluate the project?
