Please review data in highlighted. As you can see I have calibrated images in that area and the pointcloud has data but the mosaic is missing data.
NYRSTAR 4-20-22_report.pdf (1.6 MB)
It looks like the surface you are trying to image is rather homogeneous. It looks like there just wasn’t enough image content to generate enough keypoints. In the image below, the area with the red square should be much darker.
You could try adding some MTPs in this area. However it might be best to refly with more overlap or a little higher.
