POINT CLOUD CLASSIFICATION crash
Good Morning,
I’m working on a big project of 1856 photos on 450 ha approximatly.
I’ve only one problem, it’s about the point cloud classification. Pix4D Mapper crash just few minutes after run the classification.
Have you an idea about this problem ?
Thank you.
Best regards from France.
GEOMATIK.
CRASH HAPPENS AT THIS POINT
THIS IS THE LAST LOG INFOS BEFORE THE CRASH
Even with the last version of PIX4D, I’ve the same problem.
I’ve just extended the virtual memory pagefiles file fron 1go to 3go.
The process is running without problem for the moment, hope it will finish without too.
Bonjour François,
Hard to say why it crashed. We would need to deeply investigate your *.log file to find out what was going on.
As a general comment, sometimes reducing a little bit the resource could impede the software to crash:
I hope that your new settings will make it work.
Cordialement
Bonjour Marco,
I always run the software with the ressources a little bit before the max.
The solution here was the extension of virtual memory like I said in my last post.
The process finished with no crash so that’s great.
Thanks for your answer
best regards
