I have no other use for Pix4Dmapper besides making google tiles (KML,PNG) for eMotion. This is not worth it when Matic and Survey save me so much processing time. If there was a way to directly send my flight image to eMotion as a map that would be very helpful for planning missions/landings.
Hi @mike10
Thanks for the feedback. If I understand correctly, you fly an area a first time, so that you can produce and orthomosaic in PIX4Dmatic to have an up to date background map in eMotion, so that you have a clear picture of the area you’re going to fly. Then, you would make another flight plan to make a more detailed map? I’m not sure I got this right, please correct me if I did not get it.
Do you know if eMotion takes any other formats as input, e.g. geolocated JPG? I couldn’t find any documentation about this with a quick search. May be worth to ask this to senseFly too.
Well noted though, I believe that KML export could be practical in any case for viewing in Google Earth, etc…
Hi Pierangelo.
Was there any further development into the export of KML images?
Kind regards
Johan.
Hi Johan,
We are currently looking into this and will give you an update soon.
Thank you,
Kind regards,
Vishal
Thanx Vishal.
Will the KML images also open in Google Earth?
Kind regards
Johan.
Hi Johan,
That is the correct. Currently, the goal is to convert the orthomosaics to kml files and view them in Google Earth.
Kind regards,
Vishal.
HI Vishal.
It’s been 9 months, you guys still working on the solution for kml files?
Kind regards
Johan.
@mike10 @bill.jones @johan.vanderwesthuizen you can export the orthomosaic as a KML (or KMZ) since PIX4Dmatic version 1.74. I confirm that you can use these files with Google Earth, as long as they do not exceed 1 GB. Let us know how it works for you!
Good day Rhea.The kml export to Google Earth is working quite well, thanx. Trying to import them to eMotion software for our eBEE x doesn’t work. Pix4dMapper exported a HTML file which is missing from the Pix4dMatic export. You maybe have an explanation for this, or am I missing something?
Kind regards
Johan.
