Greetings, I have installed the latest version of PIX4Dmapper (I’m currently a free trial user) for Windows 10 64-bit as instructed but when I click the icon to open the application on desktop it shows me only this interface
and then the application closes (when I open the Task Manager it shows me that the application is not running). My specs are: AMD Ryzen 7 5800H with Radeon Graphics, 16.0 GB RAM, GeForce RTX 3050 Laptop GPU (I changed the options so that the application opens with the NVIDIA graphics card and its OpenGL driver but that does not do anything). If anyone could help I would be very grateful.
I tried running the executable which runs the program from cmd and again it opened and closed then imediatelly but the following error messages also appeared:
*1) D:\Pix4Dmapper>[2022.04.28 14:31:31][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> SQLite error on SELECT name, ellipsoid_auth_name, *
*ellipsoid_code, prime_meridian_auth_name, prime_meridian_code, area_of_use_auth_name, area_of_use_code, *
publication_date, deprecated FROM geodetic_datum WHERE auth_name = ? AND code = ?: no such column: area_of_use_auth_name
*2) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> SQLite error on SELECT name, ellipsoid_auth_name, ellipsoid_code, prime_meridian_auth_name, *
prime_meridian_code, area_of_use_auth_name, area_of_use_code, publication_date, deprecated FROM geodetic_datum WHERE auth_name = ? AND code = ?: no such column: area_of_use_auth_name
*3) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_crs_promote_to_3D: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*coordinate_system_code, datum_auth_name, datum_code, area_of_use_auth_name, area_of_use_code, text_definition, deprecated FROM geodetic_crs *
*4) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_crs_promote_to_3D: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*5) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_create_from_database: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*6) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_create_from_database: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*7) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_crs_promote_to_3D: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*8) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_crs_promote_to_3D: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*9) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_create_from_database: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*10) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> PROJ: proj_create_from_database: SQLite error on SELECT name, type, coordinate_system_auth_name, *
*11) [2022.04.28 14:31:32][ 44%RAM][ 0%CPU][Warning]: Warning w9020: GDAL Error <1> SQLite error on SELECT name, ellipsoid_auth_name, ellipsoid_code, prime_meridian_auth_name, *
Could these be the source of the problem?
OK, I actually solved the problem doing what was described in the following post Pix4D Mapper not starting - #15 by kpoman
We are glad the issue was resolved.
