Desktop app will not start
I am unable to start P4D desktop app on either of my Windows10 machines as of today.
I have tried repair and re-install with latest stable version.
ERROR LOG:
Faulting application name: pix4dmapper.exe, version: 4.0.24.0, time stamp: 0x59e896dd
Faulting module name: KERNELBASE.dll, version: 10.0.15063.674, time stamp: 0x93d2100b
Exception code: 0xe06d7363
Fault offset: 0x0000000000069e08
Faulting process ID: 0x91c
Faulting application start time: 0x01d34e3aa768bac0
Faulting application path: C:\Program Files\Pix4Dmapper\pix4dmapper.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report ID: a476493c-3c24-4992-a145-8055a35f8cfb
Faulting package full name:
Faulting package-relative application ID:
INFO LOG:
Fault bucket 120856913254, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: pix4dmapper.exe
P2: 4.0.24.0
P3: 59e896dd
P4: KERNELBASE.dll
P5: 10.0.15063.674
P6: 93d2100b
P7: e06d7363
P8: 0000000000069e08
P9:
P10:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4B0.tmp.dmp
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER52E.tmp.WERInternalMetadata.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER53D.tmp.csv
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER54D.tmp.txt
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_pix4dmapper.exe_af4be229c36230f4bded8e19da6fb6b3c6db9214_c7905241_1ea90fdb
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: 841176e4a4d570328a707f11478660b9
I would suggest the following:
  1. In the Search Windows type, type program and select Add or remove programs in the Settings list.
  2. Scroll to find Pix4D Desktop and click the application.
  3. Click Uninstall.
Sometimes, there are leftovers folders. Please check that the files below do not exist:
  1. On the path where Pix4D desktop (Pix4Dmapper) is installed: C:\Program Files\Pix4Dmapper make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
  2. On the following path: C:\Users\pix4d\AppData\Local\pix4d make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
  3. C:\Users\pix4d\Documents\pix4dmapper make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
  4. On windows the search bar type: regedit and then search for the folder stored in the path: HKEY_CURRENT_USER\Software\pix4d and make sure this folder does not exist anymore. If it exists, DELETE this Pix4Dmapper folder.
  5. Restart the computer.
Then proceed to re-installation.
Let me know how it goes.
Same thing here too. With 3 win 10 PC’s.
Got at least one working by following your instructions.
Thanks Pierangelo!
Matti Hytölä
Hytola Engineering
Thanks Pierangelo, I will give this a try and report back ASAP.
That seems to have worked ok, thanks. Lost a couple of days processing though. :frowning:
@Matti Hytölä: ok, one solved! :slight_smile: Let’s try to solve the two others now. Can I ask you to create another post in the Processing topic of the community? As the problem seems to be different on the two other machines I’d like to keep them separated.
@Matt Ell: Glad that it solved the issue on your machine! Sorry for the couple of days that were spent troubleshooting the issue!
Hi Pierangelo,
Actually all three are now working. 2 with real license and 1 with discovery.
BR, Matti
Hi Matti,
Awesome! Good to hear. :slight_smile: Thanks for letting me know.
Pierangelo
This seems to happen every time when license goes old.
Hi Matti, could you please provide more information: the software version that you currently have installed, the version that you had previously, is the program crashing or do you get an error message?
I am working with the latest version of Pix4D Desktop 4.5.6. I did the uninstall and reinstall and am still not getting the program to load. any suggestions.
This is just happened to me on vers. 4.6.4 of Pix4D Mapper desktop version. I tried the uninstall and reinstall and it still is not working. Just the initial splash screen appears showing the app name and says “Creating Application…” and then disappears but with no software loading.
Welcome to the Pix4D Community!
As stated in the other post, please try to uninstall and reinstall Pix4Dmapper completely and, if you are using an NVIDIA graphics card, update to the latest driver version.
You can find detailed instructions here:
Cheers
Hello seems that have the same problem Pix4D is not starting.
I have already updated the Nvidia drives and completely uninstall Pix4D Mapper.
But still the problem exists.
From the event viewer I have the following messages
Faulting application name: pix4dmapper.exe, version: 4.7.5.0, time stamp: 0x619f5b1a
Faulting module name: ucrtbase.dll, version: 10.0.19041.789, time stamp: 0x2bd748bf
Exception code: 0xc0000409
Fault offset: 0x000000000007286e
Faulting process id: 0x2628
Faulting application start time: 0x01d83548e723a11f
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 55e6cc71-4c64-4b38-965b-5043d6794d1a
with the following details
BODY{font:x-small ‘Verdana’;margin-right:1.5em} .c{cursor:hand} .b{color:red;font-family:‘Courier New’;font-weight:bold;text-decoration:none} .e{margin-left:1em;text-indent:-1em;margin-right:1em} .k{margin-left:1em;text-indent:-1em;margin-right:1em} .t{color:#990000} .xt{color:#990099} .ns{color:red} .dt{color:green} .m{color:blue} .tx{font-weight:bold} .db{text-indent:0px;margin-left:1em;margin-top:0px;margin-bottom:0px;padding-left:.3em;border-left:1px solid #CCCCCC;font:small Courier} .di{font:small Courier} .d{color:blue} .pi{color:blue} .cb{text-indent:0px;margin-left:1em;margin-top:0px;margin-bottom:0px;padding-left:.3em;font:small Courier;color:#888888} .ci{font:small Courier;color:#888888} PRE{margin:0px;display:inline}
1000
0
2
100
0
0x80000000000000
49001
Application
rs-lab-05
pix4dmapper.exe
4.7.5.0
619f5b1a
ucrtbase.dll
10.0.19041.789
2bd748bf
c0000409
000000000007286e
2628
01d83548e723a11f
Hi @apapak,
Welcome to the Pix4D Community.
Thank you for the message provided.
It seems the problem is connected with the faulty ucrtbase.dll file.
If you know how to repair a Windows DLL (ucrtbase.dll in this case) and you are confident with the procedure, you can proceed with this. Otherwise, you need to reinstall Windows operating system.
Unfortunately, this is outside of our control.
Please let us know how it goes
Have the same issue! Worked on the same PC but now anymore… Have you found any solution without reinstalling Windows?
LOG
Viallisen sovelluksen nimi: pix4dmapper.exe, versio: 4.6.4.0, aikaleima: 0x60098a2d
Viallisen moduulin nimi: ucrtbase.dll, versio: 10.0.19041.789, aikaleima: 0x2bd748bf
Poikkeuskoodi: 0xc0000409
Virhepoikkeama: 0x000000000007286e
Viallisen prosessin tunnus: 0x6c4
Viallisen sovelluksen käynnistysaika: 0x01d8bc64a86615ca
Viallisen sovelluksen polku: C:\Program Files\Pix4Dmapper\pix4dmapper.exe
Viallisen moduulin polku: C:\WINDOWS\System32\ucrtbase.dll
Raportin tunnus: 0e96f651-59cd-41b7-bb1b-ca174fa03122
Viallisen paketin koko nimi:
Viallisen paketin suhteellinen sovellustunnus:
Hi @vyacheslav.kostromin
Did you try to completely uninstall PIX4Dmapper and then install it again?
Also, if you are using an NVIDIA graphics card, update it to the latest driver version.
Please let me know how it goes.
Have tryed to fix Windows register, stop antivirus and firewall, deleted GDAL libraries. Still same problem with Pix4D. Other soft works well
And off course I reinstallet it several times with diff versions
