While things are getting sorted out with the DJI SDK and the Mavic 3E and Matrice 300, would the team consider adding a KMZ export to flight planner or the app? The flight path KMZ can be imported into DJI Pilot 2 and ran from there.
It looks like capture pro is already creating these KMZs, but not until you’re connected to a drone which isn’t that convenient. It’s also unclear which KMZ is the correct one when you’re trying to go through the app files.
