Export kml file from pix4d mapper
Hi.
I recently purchased a mavic 3 enterprise. I know that I cannot fly it on pix4d capture. Is it possible to export the boundary of a flight mission from pix4d mapper as a kml file. I want to be able to ( if possible) fly exactly the same mission parameters as I did on pix4d capture. If I can export the boundary, as a kml file, I can hopefully import it onto the Mavic 3e controller and fly exactly the same area.
Apologies if this has been previously asked/explained before.
Greg
Hi Greg,
It is possible to draw a boundary in PIX4Dmapper and export it as a KML. However, I don’t know if the DJI flight app supports the importation of a KML. You will need to investigate that. I hope this helps.
