I took a test today with the Pix4DCapture software and the Drone M100 with the Zenmuse X3 camera in Circular Mission mode. Curiously, the photos were captured outside the circle and not internally, that is, for the target.
What could have happened? I have not seen a function to invert the capture of these photos.
This is indeed quite strange and not expected as the pictures should target the point of interest (POI) in the center of the flight. The drone translates to always face the POI. This point should be defined in DJI GO. The camera angle is set to focus on the ground. In other words, the camera angle is closer to vertical when the flight altitude is higher.
Estou enviando estas fotos com o resultado da captura que eu informei! Não entendi como definir o alvo no DJI GO. A Pix4D Capture não deveria ter esse recurso? Você poderia explicar como proceder com este tipo de pesquisa?
I am sending these photos with the result of the capture that I informed you! I did not understand how to set the target on the DJI GO. Should Pix4D Capture not have this feature? Could you explain how to proceed with this type of survey?
After checking with our app developers, there is bug for P4, P4P and M100 drones. It is exactly what the screenshots display. It will be fixed in the coming iOS released (by the end of this week). Sincere apologies for the inconvenience.
Pix4D Capture’s orbit function did not work … As shown in the attached Picture
, it was in the camera configuration! I did a test with the 3D mapping function and it worked normally! I think the program was looped trying to confuse the angle of the camera! I tried it for 3 times and nothing happened!
I did this procedure to shut down all the system, Drone and Radio, but the problem persisted!
In 3D Mapping did not happen and the flight was successful.
Please ask developers to check the Camera Setting up function.
I did a test with another application (DJI GS PRO), which is paid, worked correctly, but I really like Pix4D Capture and it would be interesting if this ORBIT function works correctly, even if we have to pay a fair value for the maintenance of this excellent system .
The camera can take some time to be ready. To solve this, we recommend to restart the mission over to refresh the status of the takeoff checklist and force the reset of the camera.
After re-booting everything (app, controller, drone), does it work or are you able to take off and start the mission?
Next time you give it a try, please send us the log files so that we investigate further.
