My lidar sensor, Geocue 535, has one nadir camera plus 2 oblique cameras that take pictures while collecting the Lidar data. I process my data in LP360, but need a way to make the orthomosaic for the project. With the Lidar, we typically only do a 50% overlap. With the incorporation of the two oblique cameras plus the nadir, will matic be able to use all three cameras to come up a good image? Will the workflow be the same as for nadir only images?
Hello @blakemd123456 , The workflow should be the same. If you have the metadata(Camera orientation), it would be easier for camera calibration if you have enough overlap. For large camera frame, you might not need the same overlap as drone but 50% with just a Nadir images might not be enough but as you have 2 oblique images which might help. I would suggest you to test it using PIX4Dmatic and see if are able to process it. You can signup for the trial as explained in the below support article,
