Would you please let us know if the 3D mesh is processed using PIX4Dcloud?
A fix has been deployed today so the 3Dmeshes should be produced in the right color from now on.
The issue was related to a wrong parameter that was used in the cloud when the 3Dmaps template was used.
The other results work perfectly, the only problem was the 3Dmesh where sometimes the color-balancing was not correct.
