Hi folks,
Does anyone know if there’s a way to manually insert grid points to create a more densely defined TIN surface at key areas? I’m trying to model a sidewalk at a building edge, and some of the round building faces are causing gaps created by the set grid.
I created a polyline to define the back of sidewalk and set it as a breakline for the TIN creation, and this has worked will where there are points on the wall (left side of image), but there are areas where the grid didn’t create a point on the wall and then there’s just a gap (right side of image). It would be great if I could manually place a grid point or two to fill in these gaps.
Is this a feature that’s currently available?
Thanks!
Jackson
